‎2024-09-25
02:21 PM
‎2025-07-16
11:59 AM
Molinda Prey
Hi, everybody
I was having a trouble about MEP part appearance on floor plan. I have something modelled like this:
It's made by one single object:
But on the floor plan it shows the whole element on All Relevant Stories:
So this is the display on every floor plan but I want it to be different on every story. I want the stories to cut the whole structure and show only needed parts on the current level. I don't want to construct it hand-by-hand. Is that possible?
Solved! Go to Solution.
‎2025-06-13 03:38 PM
I found a workaround for the issue. I simply draw separate sections for each floor. The ductwork tends to join automatically and form a single object. To bypass this automated behavior, I place the ductwork slightly off to the side so that the reference lines don’t touch. Then, I extend the ducts downward until the arrow displays the hammer symbol. In this configuration, the ducts are not aligned, preventing them from actually merging.
After this "false" connection, I manually drag the duct to match the reference line. As a result, they remain separated with their respective home stories while still being accurately aligned with the reference lines.
Unfortunately it is just workaround way to achieve the result
‎2025-02-05 01:06 PM
Have you found a solution? Or is it unsolvable with the software as it currently is? 😞
‎2025-02-06 04:17 PM
Hi, did you tried to put "real section" in plant and section?
‎2025-06-17 12:42 PM
Not really. I don't know what it means.
‎2025-06-17 12:43 PM
Yes, I think the approach of DavitBotchorishvili is the optimal one.
‎2025-08-21 03:45 PM
I've found the exact same solution to this problem. It's good to know I'm not the only one struggling with this. The thing is, I don't think this problem should be solved like this...
I miss the AC 25–26 MEP modeler! This new MEP modeler isn't functional!
