Marker Object Help
Is it possible to use marker objects instead of labels for windows/doors and have them turned off on specific plans but turned on for others?
I set them up for my floor plans however they also show up on the site plan which id prefer them not to be on.
Thanks.
David Maudlin
nonco:
I'm not sure what you mean by Marker Objects. If you are referring to the Dimension Marker that is part of the Window or Door, their visibility can be controlled via Model View Options (MVO): MVO > Options for Construction Elements > Door (or Window) Options: with Markers. If you are referring to an independent marker of some other type, then use its Layer visibility (Show/Hide).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
