heathldesign
import custom label
hi there, i found a label online (label JM16 if anyone knows of it) that will allow me to create callout labels, sort of, but now that i've downloaded it, i have no idea how to import it. it's no good as an object, there are no associative features. is there a way to import into the label tool?
MAC Studio 2022 M1 Max, 32 GB RAM, 10 cores, AC27 5030 Apple Silicon USA Sequoia 15.3. AC 27, 6000 USA
1 Solution
BrunoH
Is this that Object ?
If yes this is not a label, only a 2D Object.
For an object to be a label his Sub-Type must be set to "Label".
You can change the Sub-Type of this object (work on a copy) but this won't be sufficient for it to work as a real label.
You can then choose it in the label Tool and associate it with an element like any label but it won't automatically display element information as his 2D script isn't programmed to do it. You'll have to adapt the script to extract and display the information you need.
ArchiCad 3.43 to 28
MacOS Monterey
Go to post
9 Replies 9
Matteods
Hi
You can have a look to this:
https://help.graphisoft.com/AC/26/INT/_AC26_Help/070_Documentation/070_Documentation-84.htm
With an indipendent label you have the opportunity to choose "load other label"
You can try if this works for you!
Greetings,
Matteo.
heathldesign
Hi Matteo,
when i follow those instructions and navigate to the label i downloaded, which is it's a GSM file, it's greyed out.
Matteods
Hi
Can you share the label?
If you upload it as object , it's possible or not? Does it appear grey too?
What kind of label you need ? Maybe we can create a proper one
All the best,
Matteo
BrunoH
Normally, if this is an object saved as a label, add it to your project object library and the label should appear in the label tool options.
ArchiCad 3.43 to 28
MacOS Monterey
heathldesign
Hi Matteo, i don't know how to upload it here. i'm trying to create a simple unassociated keynote label. i'm using AC27 and of course GS introduced them in AC28.
heathldesign
Hi Brunoh,
it's in my embedded library, but not available in the label tool.
Matteods
Hi if you need just a recall number or letter you can place a independent label with a custom text:
https://help.graphisoft.com/AC/27/INT/_AC27_Help/070_Documentation/070_Documentation-78.htm#XREF_243...
Otherwise there is also this add-on:
https://youtu.be/adsnMmEQPic?si=89O-o7_jvypYuYRX
Have a good day,
Matteo
BrunoH
ArchiCad 3.43 to 28
MacOS Monterey
heathldesign
Thanks Brunoh, that's fixed it. awesome!
