Master Layout Costum Size
Is there a minimum to the custom size of the Master Layout in AC 13/14?
I am trying to set up a business card layout 85x54 mm. I can not get it smaller than 85x80 mm. Is it not possible or what do I do wrong?
6 Replies 6
hello,
my advice would be to use scale.
For example chose 850x540 dimensions.
Later, scale then printing.
I tried master layout margins, looks like 80x80 is the limit.
Thank you. There will (always) be work-arounds. I scaled and saved as a pdf, changed it to Tiff in PDF Creator, cropped it with with Gimp. Now I have the result I want.
Erika Epstein
Or set up an A4 layout sheet. In archicad you can set up multiples of your business arranged to print on the A4 sheet, or just one card and place multiples of this drawing on the layout.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
That's how I normally would do it. But this one had to be a single business card and Tiff. I printed/saved a Tiff file with PDF Creator and used Gimp to convert to the right scale and dpi.
Tip: PDF Creator is much better at saving image files (by printing) than ArchiCAD itself. My attempts to export a layout as Tiff with ArchiCAD gave a very grainy text.
Erika Epstein
I was addressing setting master and layout to match the size paper you are printing on. I've not seen individual business card sized sheets of paper.
And a tif too
glad you figured it out.
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Thank you Erika. Neither have I. This was for upload to a website claiming to have a super duper special deal on quality business cards with extra free gifts to attract new customers.
Apparantly not pro people. Not flexible with the size or format of upload.
The Tiff worked best. But after all this I cancelled the order anyway.
