Missing lines between wall and objects in sections when skins separators are hidden in GO
Martin Jan Rosa
When I use the graphic override rule that hides my skin separators, also the lines between walls/slabs and objects in sections are hidden. I have tried several things (different layers, materials, intersection group numbers etc.) but it seems that AC still thinks about the line between wall and object as another skin separator and thus these lines are hidden.
Does anybody know how to keep my settings of the graphic override and yet keep the lines visible?
It seems to me that the only way is to keep some distance between the object and wall/slab (like I've kept between the constructions and a cabinet on the right side of the image – there is 2 mm gap between the floor, wall and ceiling and thus the thick line is visible there...).
www.martinrosa.cz
GRAPHISOFT Certified Archicad BIM Manager, 2021, 2023
AC 28 CZ @ macOS 15.0 @ MacBook Pro M3 Max
0 REPLIES 0
