Model View Options - Object and doors
Guillermo1
Hello, how can i eliminated the MVO of older version and only have the MVO of AC26?
Operating system used: Mac Intel-based
CosminF
Do you have any objects loaded from those respective libraries? From Archicad19 in your case. Maybe removing those would remove the options for them.
You can check that into library manager.
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
CosminF
Thanks! Now its show AC26 again
Setup info provided by author
