New Window & Door Holes Showing in Demolition Plan
How can I make it so that you can not see the new window and door openings in my demolition plans? They are confusing as to whether the holes are existing windows to be demolished or not.....
1 REPLY 1
Just use Renovation Pallet.
When you choose Existing Window to be demolished it will automatically be represented as an element to be demolished on the Demolition Plan. Moreover, there will be a new wall in the Construction plan.
With new windows, it's the same. So if you add a new window it will be reperented as a wall to be deomlished in Demolishon Plan.
