Geof Gainer
Override the outside/top and inside/bottom lines in Graphic Overrides?
In Composites, I have the outside/top and inside/bottom lines of my walls set at the default Line Pen 1, which is pretty heavy. They look ok in detail view, but at 1/4" = 1' plan view the lines blur into each other and look illegible. They would look a lot cleaner if the outer lines were thinner.
Is there a way to isolate the outside/top and inside/bottom lines in Graphic Overrides? I could use a different pen set for the drawings in the layout, but I'd like to keep Line Pen 1 to read correctly for other items in the same drawing.
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
Unfortunately no, Graphic Overrides always affect the whole element.
Geof Gainer
Thanks Laszlo, Jared Banks has suggested a different pen set but that has drawbacks as well.
