rob2218
PARTIAL WINDOW DOTS OF DEATH? NOT SURE WHY
SEE ATTACHED.
Seems for some reason, all of a sudden, my windows started to display a "partial dot of death"?
Can anyone help?
AC22, latest fix.
Dell Laptop.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
5 Replies 5
Expand the 'Warnings' section of the Library Manager.
What does it say in there?
Any missing objects?
Stress Co_
Could it be a missing Dimension Marker?"
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
"Dimension Makers".....humm...
I'm curious.
Can someone please explain how to 'LOAD' either section tag markers or other markers?
I've never understood 'where' within the folders do I go to load other marker types?
Where do you store these 'marker' types?
what file format at they? XML?
Whats the process for loading 'other maker' types if indeed they are the missing dots of death?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Lingwisyer
Guru
They are added like any other library object. File => Libraries & Objects => Library Manager => Add. What ever it is, is probable listed within the thousand warnings you have with that file...
Ling.
rob2218
Thanks Ling,
but....what extensions am I looking for?
Seems I'm not sure where to look.
Each time I try to "add" another marker...I have no clue where to find them?
Where to even go in my folder structure and it appears that you can "import" markers others have programmed as well but again..............just not quite sure just how to do that.
i>u
Edgewater, FL!
SOFTWARE VERSION:
