PDF did not show dot fill
My Archicad and print showed the dot fill but it disappeared in PDF. Actually it appeared for a while when you first view the pdf but then disappeard like having smth cover over it. Anyone know why ?
1 REPLY 1
Podolsky
Ace
The main problem here, that ArchiCAD saves each dot from vector fill as separate dot. Because you are covering big area with dot fill you are getting big file and your PDF application might simple not render all these dots.
The solution to similar problem - try to avoid using vector fills for large areas (it mostly happens for site plans). Use symbol fills and photo fills - then it will be saved into PDF as fill. File will be smaller and PDF viewer would be able to render it better.
