2004-01-20 06:25 PM - last edited on 2023-05-18 12:16 PM by Gordana Radonic
2004-01-20 06:49 PM
2004-01-20 07:33 PM
2004-01-20 07:36 PM
drew wrote:Add memory.
i have tried that....
unfortunately i am using an HP DESIGNJET 500 w/ the HPGL2 card.
and its telling me that I do not have enough memory to print.
2004-01-20 08:28 PM
Djordje wrote:hah!
Add memory.
2004-01-20 09:55 PM
drew wrote:I am not too familiar with the 500, but the 650 I use has an advanced setting that will allow you to process the document in your computer...check your plotter properties
hah!
u mean theres no other way?
2004-01-21 08:16 PM
drew wrote:drew,
2004-01-22 06:01 PM
2004-01-23 08:07 AM
drew wrote:The golden rule is to fit the PlotMaker file into the printer's memory; if you computer has enough, than the driver settings should be such that the print is processed in the computer. However, that can slow the machine down, and IMHO printers should take care of that. In a multiuser environment, computers can grind to a halt if everybody is processing their own prints, and thewhol eoffice is idling because the memory in the print device is not enough.
I tried the "avoid out of memory" and it worked pretty good... i mean, a few lines were missing but it'll do for now...
2004-01-24 02:55 PM
The golden rule is to fit the PlotMaker file into the printer's memory; if you computer has enough, than the driver settings should be such that the print is processed in the computer. However, that can slow the machine down....It all depends more on the speed of connection to the machine..
