rob2218
PLine - How to use in a "Life Safety Plan" for perimeters?
How can I get (extract) the length of a pline that has multiple segments to use for a "Life Safety Plan" diagram? I need to show length segments of each part of the pline?
thanks,
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
14 Replies 14
rob2218
this has come up again...can't seem to find out just exactly how to show (connected to the pline) the length of the pline for "life safety" plans (purposes)....
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
I got that "italian" line object to work....but I need it to say "TRAVEL DISTANCE" somewhere in the script file.....if anyone knows italian and knows GDL scripting...could you take a look at the script file and tell me where and in what symmatics (quotes? paranthesis? or what) could I alter the script routine so that it simply adds the words "TRAVEL DISTANCE" to the object?....much appreciated.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
VIOLA!!!.....it appears that the object itself comes with "preffisio" and a "sufficio" (prefix and suffice) which is fantastic!....you can add custom text to the front AND the back of the object...
i>u
Edgewater, FL!
SOFTWARE VERSION:
sinceV6
Depending on what you mean by "connected to the pline", you can also use the tools to model your travel distance. For instance, you could use 0width&height walls or beams, placed on a separate layer with another intersection group.
This way you could schedule it by floor, and you can even show it in 3D using a profile in a fancy way.
Best regards.
rob2218
I guess I wasn't clear in my description. That object from Italy works just like I need it.
i>u
Edgewater, FL!
SOFTWARE VERSION:
