I have a similar problem. I have been using separate Door & Window Schedules for quite some Versions of AC. With AC22 I couldn't import my .xml schedule template (?), so I had to design a new one to fit my expectations. Once finished I did all Annotations, saved the Schedule as a dedicated View (renovation status as "new construction") and placed the drawing on a layout. On the layout I am using the option "Split Drawing among Multiple Layouts". This option generates 10 separate layouts for the whole Schedule.
Now I have a problem. I need to export this whole documentation to DWG, which is no problem using the Publisher. But after reviewing the resulted exported DWG I see only the last part of the exported Schedule on each and every one Schedule layout. To be clear - I get all 10 Layout pages exported, but all with the same content - which is the last Schedule page as seen in Archicad.
Funny thing about this is that publishing the exact same publisher set to PDF works fine.
Is it me doing something wrong here?
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
