2004-06-02 12:02 AM - last edited on 2023-05-17 07:35 PM by Gordana Radonic
2004-06-02 12:43 AM
2004-06-02 08:42 PM
Link wrote:Do I understand correctly that Display Options in PM are not global and are View Set applicable?
Just override the pen settings for that particular 'background plan' and make all the pens zero mm! .
2004-06-02 11:24 PM
Do I understand correctly that Display Options in PM are not global and are View Set applicable?Nope. Display Options
How about a way of controlling the line types in PM?
2004-06-03 12:25 AM
Link wrote:Why not in ArchiCad set a ViewSet for a back ground plan with Display Option of "hairlines" set, bring it in to PM and overlay it with the main drawing and then grouping them?
Nope. Display Optionsareglobal, what I am suggesting is to change all the pen colors and weights to zero in your 'Background Plan' view only.
2004-06-03 12:37 AM
2004-06-03 02:21 AM
Aussie wrote:I'm not sure that pixel is the right word, but you are correct that a zero thickness line will print at the minimum thickness of the printer. This will be one dot in HPGL but may be a bit thicker in Postscript or PDF.
The way i understand it, hairline is 1 pixel. Hence a printer with high resolution will print a thinner line than one with courser resolution
2004-06-03 03:10 AM
Matthew wrote:Nor was I
2004-06-03 05:38 PM
Why not in ArchiCad set a ViewSet for a back ground plan with Display Option of "hairlines" set, bring it in to PM and overlay it with the main drawing and then grouping them?Because setting the Display Options to Hairlines/True Weight in ArchiCAD has no effect in PlotMaker. Even though it falls under the category for Display & Output - this refers to printing, exporting etc. Views will import into PlotMaker with True Weight, regardless. And PlotMaker's Display Options are for Display only (take a look!) - that is to say that changing them will have no effect on the output.
