Vitruvius
Plotmaker PDF Output
I've been outputting PDF on both PC and Mac and have noticed that the Mac files aren't as fine a resolution as the PC Amyuni PDF files. This is the same AC project and PM layout?????
The platform setups are:
1. PC / Windows 2000 / AC 8.1 / PM 3.1
- files are PDF'd from Plotmaker using Amyuni PDF driver
- my default printer is an HP 5000 laserjet
2. MAC / OS 10.2.3 / AC 8.1 / PM 3.1
- files are PDF's using print command in Plotmaker
- my default printer is an HP 9300 inkjet
The PDF output has been printed on both printers - basically the PC files look nicer on screen and the printouts are far superior on both HP printers. Any thoughts or suggestions?
Many thanks!
Cameron
Cameron Hestler, Architect
Archicad 27 / Mac Studio M1 Max - 32 GB / LG24" Monitors / 14.5 Sonoma
30 Replies 30
Aussie John
Joseph, Dont publish, just print and selct save a PDF in the print dialog. You will then get a booklet of the "printed" layouts.
I also recommend a little freeware program called- Combine PDFs which allows you to add/subtract/rearrange the orger of a PDF booklet.
(search in www.versiontracker.com)
Cheers John
[/size]
