Plotting to pdf - problem opening the pdf
Having problems with plotting to PDF on only a single job. not sure if its a setting if clicked and not realized but i cant work out what is doing it.??
just on the one job when i plot a PDF all is fine until i try to open the PDF. when i do i get this error (see attachment) from adobe. and it fails to open the PDF and crashes. im assuming its a issue with the PDF coming out of archicad, cos every other PDF works fine. iv tried re plotting it and its the same.
3 Replies 3
anyone?
Is the word 'plot' a slip of the tongue/fingers? You should be printing, not plotting... (Or, from Publisher, you can either print or save to PDF.)
in the publisher. save files to pdf
