Plotting woes...
Hello all.
I have a Mac and use AC9 educational version. My school's plotters are on a network that only has PCs and Autocad thus I can't find a way to plot my images and keep the line weights/ scale correct. Our school has 2 HP 1055CM plotters. So far I've sent my drawings to plotmaker where i saved them as .DWG files. I then try to open them up in autocad so i can plot from the computers in the lab (this is all at the suggestion of our "handy" tech guy). I never get the correct scale nor do i get any of the lightest line weights ( the line weights 18 and above all look the same.)
Any suggestions on what I am doing wrong or what I can do to plot the images true to what i have in my computer?
I've tried saving as a plot file and printing straight from that whereupon only 1 line weight was printed. I've tried saving as a PDF but the scale gets messed up. Several of us in our studio suffer from these problems
Thanks.
4 REPLIES 4
PDF would be my suggestion (Publish from plotmaker, as opposed to printing), I don't know why your scales are getting messed up. You should be able to set your scale to 100% at both the Plotmaker and and the PDF printout end. What exactly is happening to the scales?
The drawings end up being smaller than they should. I can't print directly from my computer. The way we pay for the prints messes that up so I have to take the files via jump drive to the lab.
I'll try the PDF.
Thanks.
edit: I can't publish it, I guess because I'm not connected to a printer.
Have you installed the Amyuni PDF converter from your AC installation CD? Are you publishing from Plotmaker?
Steve, is your Mac on the network? We plot to an ancient HP455ca over a network from G5's . To do this I installed GIMP drivers for our plotter and create a printer on the Mac with a manual IP address for the plotter and selecting the plotter model for the driver setup. We then either use the plot command direct to the plotter or, better, save to a spool folder and use grphisofts Plotflow for OS X to control trnasmission to the plotter.
This has produced excellent results with good lineweights and scale using AC 9 and Plotmaker
