‎2008-02-19
09:07 PM
‎2023-05-30
03:20 PM
Rubia Torres
‎2008-02-19 09:33 PM
‎2008-02-19 09:39 PM
newbr33d wrote:Start - Control Panel - Regional and Language Options - Regional Options tab - Standards and formats - Customize - Numbers tab - Digit grouping symbol
Hi!
I can't find an option or something like this to eliminate the "." (point) in measuring.
‎2008-02-19 09:53 PM
‎2008-02-19 09:56 PM
newbr33d wrote:I'm glad I could help. (cu placere :p)
I've changed theDigit groupingand the problem is solved! Really thanks Adrian Tudoreanu! (mersi 😛 )
Anyway, hope someone knows how to do this in Archicad.
‎2008-02-19 10:02 PM
Anyway, hope someone knows how to do this in Archicad.I thought you could adjust the dimensions to millimeters as I said originally, under project preferences? You may need to switch it to meters and then back again if it doesn't update correctly.
‎2008-02-19 10:54 PM
Peter wrote:Hi Peter,
‎2008-02-19 10:57 PM
