Problem with drawing scale
Hi everyone,
I'm setting up a master layout for a project done in AC13.
I have a problem setting up auto text information.
In particular, I set my layout to show the scale of the drawings (plans, sections, elevations). The problem I have is that Archicad will also show the "scale" of photographs and other images...
How can I select what scale to show and what not to?
Thanks!
Enrico
10 Replies 10
... this happens also if I insert a schedule on the layout. AC will show it to scale 1:1.
Select the drawing/image/photo, go to drawing selection settings (command + T on a mac), then title, and turn off the scale. Or select it to show not to scale.
Furthermore, you might want to read this post about how to insert external content and the difference between Figure & Drawing tool:
http://archicad-talk.graphisoft.com/viewtopic.php?t=33998
Jared Banks, AIA
Shoegnome Architects
Archicad Blog: www.shoegnome.com
Archicad Template: www.shoegnome.com/template/
Archicad Work Environment: www.shoegnome.com/work-environment/
Archicad Tutorial Videos: www.youtube.com/shoegnome
Wow, I cannot belive I worked with Archicad pretty much every day in the last two years and never used the Figure tool. Never crossed my mind either....
Thank you, this will help me get what I want.
Enrico
...and what about independent worksheet or imported pdf files?
Archicad will still show some weird scale numbers for that!
David Maudlin
Enrico wrote:
...and what about ... imported pdf files?
Use the Figure Tool, when in the Figure Tool Open dialog box, set the Enable pop up to "All Files".
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
I have the exact same problem with a schedule I inserted in the layout.
If I enter an automatic text in the layout, Archicad will show all scale values related to actual drawings (1:100 and so on) plus a 1:1 scale that refers to the schedule. How do I get rid of that?
Thanks!
Enrico
Erika Epstein
Select a drawing, right click and chose 'Set as autotext reference'. Until you change the reference designation, all autotext will refer to this placed instance of the view, i.e. the drawing selected.
The key point is to only select one drawing at a time.
HTH
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I tried to set it as you said, Erica, but it didn't do anything for me.
It's still showing scale 1:100 and 1:1
Sorry I forgot to mention that the automatic text is placed in the master layout.
Does this change anything? I'm really sorry I didn't mention it before.
Thnks everybody for the help!
Enrico
