Profiled Columns Label Dimensions
Takis
Hi, I get wrong dimesions on column labels with profiled cross section.
Has anyone else experienced the same situation?
MacPro 2013
Windows 10x64 on Bootcamp
Takis.
5 REPLIES 5
DGSketcher
Legend
With the Dimension Label I get the same error but only when using a complex profile. You should report this to your support provider.
Guys, I will report this to GRAPHISOFT.
LucaP
Hi Takis,
Just quick question. Did you remember to set the nominal width and height parameters in your profile? Perhaps it somehow got dislocated and the label gets the data from them?
Łukasz
Łukasz Pietraszko
ArchiCAD 26 PL, since AC20 | WIN 10 Home
Intel Core i7-7700HQ 2.8 GHz | 16 GB RAM | NVIDIA GeForce GTX 1060 6 GB | 500 GB SSD
Takis
Dear Lukasz, yes off course I checked it. With a rectangular complex cross section it is difficult to make mistake with the nominal dimensions.
Please try it.
Takis.
LucaP
Hi Takis,
You're right I should've checked before writing, sorry about that. I thought that maybe there is some simple solution to that problem but apparently not.
It behaves as you've described it. I just went a little deeper into the issue and it appears that with the beam tool Dimension Label shows correct values. In the image below I've applied the same complex profile to beam and column.
Łukasz
Łukasz Pietraszko
