Property Label Issues
qbic-ft
I created a custom classification with properties for material tagging. It was working fine and then suddenly after updating the elevations the information disappeared. I checked the label and it's looking for the right custom property. The object has all the info available.
I created a new file with the standard template and I replicated the properties, but i got the same problem... I label with showing lines instead of the info.
Any ideas?
Thanks,
Fernando
AC24 USA latest version
2 REPLIES 2
qbic-ft
This issue is because all my labels switched to " independent labels". I don't know why this happened after updating the elevations.
For what it's worth, you can select a Label and CTRL+click an element to re-associate the Label with the element.
