2024-09-03
06:17 AM
2024-12-30
05:34 PM
Molinda Prey
Hi. I have a trace reference loaded in my layout. I have selected the correct Document Options (print reference) however when I publish, the image falls behind other objects and isn't clearly visible. It looks great in my layout, and I have selected 'Reference on Top'. Attached are screenshots showing layout vs PDF.
Appreciate any help!
Josh
2024-09-03 07:36 AM
Reference on top may simply be an on screen setting, and doesn't actually affect how the view publishes.
Can you achieve the same by overlaying two views in a layout?
Bring the one you want to the front with display order and set the background of the drawing as transparent.
2024-09-04 07:50 AM
Thanks Barry this makes sense. I will give this a go.
Josh
2024-09-04 05:01 PM
It can help to save the trace reference as a view and that gives you a chance to change the layers, pen colours and use graphic overrides
