Steve Jepson
Rebuild problem
Recently I have noticed that anytime I go to another View I have to click Save in order for things to show up as are supposed to be.
This happens to lines and objects and I am not sure what else.
The fills of objects, dimensions, lines, etc...are all black until I Save, then it rebuilds with the proper display.
Is this something new with 1086 to let you know that what you are looking at has not been rebuilt or saved?
Is there some sort of rebuild setting that I may have caused this with?
Anyone else having this problem?
5 Replies 5
Thomas Holm
I've also had a Fill turn black. And I seem to recall someone else reporting the same thing. Didn't notice the Save workaround, though. Thanks!
Steve Jepson
Attached is a .pdf of what it this looks like.
It happens every time I leave a view and then come back to it.
Thomas Holm
I have seen it but not consistently. I'll watch out for it!
Erika Epstein
This happened a couple times to me. Interestingly I checked the active penset and it was changing to the printing penset for that view which is mostly black pencolors with some white and gray.
I have reported this to graphisoft US tech support.
Since upgrading drivers for everything from graphics cards to adobe I haven't seen this. I also am using files that are new in AC11, no longer ones that started out as AC10 projects.
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
Eduardo Rolon
One of the causes was the "Automatic Pen Adjustment Settings" and it was supposed to be fixed in the current update.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
