We do use the Renovation Filter all the time, but there are other forces at workā¦
I'm not sure if I can speak to the whole question, but we had a similar problem with the window sill lines coming out too heavy. I don't think it has anything to do with the Renovation Filter, which only changes the color.
You would think that the sill line setting is in the Window settings, right? Only if the window is shown as a
Symbol
. However, if you're using Model View Option > Options for Construction Elements > Window Options > Show Opening Only (as you might for a Site Plan or Reflected Ceiling Plan MVO), then it just draws 2 lines, and
ignores the Window settings.
These lines, in that case, are taken from the
Wall settings > Floor Plan and Section > Outlines > Uncut Line Pen. Essentially, it assumes you're just looking at the edge of the wall. Unfortunately, this is the same setting used to show wall outlines in elevations and other 3D views, so it's a balance between a light line you want in plan, and a heavy line you want in elevation.
Chuck Kottka
Orcutt Winslow
Phoenix, Arizona, USA
ArchiCAD 25 (since 4.5)
Macbook Pro 15" Touchbar OSX 10.15 Core i7 2.9GHz/16GB RAM/Radeon Pro560 4GB
