‎2007-11-28
05:09 AM
‎2023-05-30
03:20 PM
Rubia Torres
‎2007-11-28 11:32 AM
‎2007-11-28 09:05 PM
Thomas wrote:I've been using this automatic method of moving text for the past 5 versions of Archicad and its always worked perfectly. This is a problem with 11 not with me creating a static dimension.
I think your problem emerges because what you really do is this: You're creating an extra (static) dimension node by command-clicking. Since it's horizontally at the same location as the old node, you're confusing Archicacd into that behavior.
The way to move dimension text is to click-hold-drag it by it's low-left text node point. You can place it where you like, and you won't have that problem.
‎2007-11-28 10:31 PM
‎2007-11-28 10:42 PM
‎2007-11-28 10:54 PM
‎2007-11-28 11:03 PM
‎2007-11-28 11:06 PM
‎2007-11-28 11:08 PM
Thomas wrote:D..E..V..O
OK. BTW, what's that hat you're wearing?
‎2007-11-28 11:13 PM
