!Restored: Copy Dimension
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2007-10-17
04:00 PM
‎2023-05-30
03:20 PM
Rubia Torres
I need the relative dimensions and should be associated with the floor plan.
Anybody have a easier way to do this for coordinate and regular dimensions?
thanks in advance
- Labels:
Dimension Tools
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-17 05:08 PM
You could place hotspots at the points where you need to dimension on multiple floors, associate the dimensions to the hotspots, then copy the hotspots and the dimensions to each floor (the dimension strings will remain dynamic, but infact associated to the hotspots, not the floor plan).
See this related link -- I don't recall if I ever got around to posting a wish list item.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 01:13 AM
This is not much better than using static dimesnions IMHO, as it is a little messy. It would be better to ghost the story with dimensions and place new ones in the same position.
Link.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 02:36 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 05:35 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 05:46 PM
Place those 'common' dimensions in the new layer and create a combo and view that displays only those dimensions.
When you place a floor plan on a layout, you'll also place this common dimension view exactly on top of it. As in all versions of ArchiCAD, the alignment of multiple drawings is accomplished via a common hotspot. Place a hotspot somewhere reasonable in the plan on the ArchiCAD layer so that it is always visible (they do not print). Use this on the layout to snap the two drawings on top of each other.
The placement is a one time thing of course, and can even be in your template for future projects. The common dimensions are associative to the floor that they were placed on. The only error/omission concern now is if the dimensioned elements are no longer common...for example an upper story becomes cantilevered. This is still better than the static or hotspot oriented solution which requires editing, stretching, or re-pasting, I think?
One possible workaround anyway...
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 05:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 06:48 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 07:56 PM
Your idea of stacking/overlapping drawings on layout sheets should really be considered a standard practice and not necessarily a 'work-around.' It is kind of an additional layering system to augment the actual layering combinations used in defining views.
Thank you so much for all your great ideas.
Scott
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2007-10-18 10:36 PM
