2022-09-22 01:11 AM
Hi all,
Was just editing my revision cloud and this happened:
I just undid it and it solved the problem but had to save it and see if anyone has had this happened to them.
Before the sheep appeared:
Was just editing the nodes for the revision (might have right double-clicked it or something) and the sheep pop out.
Plus it looks pretty cool
2022-09-22 08:26 AM
That is one of many easter eggs hidden in Archicad!
Easter Eggs in Archicad - Graphisoft Community
| Archicad 4.5 - 29
| HP Z840 | 2× E5-2643 v4 | 64 GB RAM | Quadro M5000 | Windows 10 Pro x64
| HP Z4 G4 | W-2245 | 64 GB RAM | RTX A4000 | Windows 11
2022-09-22 09:17 AM
you need to try the tetris. 😎
2022-09-22 12:16 PM - edited 2022-09-22 12:17 PM
this looks like an unhandled exception in inputted values in GDL script (cloud is essentially library part). in other words you could set values of GDL parameters (e.g. moving the diamond hotspot) to a value that is outside of (logical) range which in turn caused collapsing the cloud shape calculation. eventually you could keep this as is... it would definitely bring anyone's attention to the revised detail.... which is essentially the purpose of clouding. 🙂
