Revit Vs. Graphisoft Archicad
chase88
I'm going to start working in Graphisofts Archicad in a residential architecture class I'm taking. I've only used Revit up until this point. How do the two compare and what frustrating things can I expect to find in Revit?
This has been discussed many times before.
Just search for ... Revit v Archicad
You will find a couple of posts.
Further searching will find many more posts.
They are totally different software, so it is not easy to compare them.
Both have their good and bad points, and each will do the same thing in different ways.
ryejuan
you will enjoy using it, freedom to design. 😎
but like @Barry Kelly said it does the same things differently now its up to you how you can adjust to that change but pretty much easier than revit, less annoying pop up alerts. 😆
In the end what is your Objective?
ArchiCAD 9 onwards
