2022-05-06 08:13 PM - edited 2022-05-06 11:16 PM
The roof was showing yesterday, but now it is missing. It shows up fine in 3D and when I work on the roof storey.
EDIT: Solution in case anyone gets the same problem. At the place I was in the picture, right-click the house. Then click on "Modify Source View Settings". Then change the Layer combination to 3D Documentation/Visualization.
2022-05-07 02:08 AM
Hi. Did you insert this drawing into the layout from the view map or the project map? If you did the latter you will keep getting it changed.
2022-05-07 09:28 AM
Can't remember, I think View map. Is it supposed to come from Project map?
2022-05-07 07:00 PM
Hi, no, from the view map
