Scaled dimension text not behaving
Hate asking stupid questions - but how do I get the dimensions to scale in the layouts? I place dimensions in the project at a suitable size for 1:100 layouts, but now I need a 1:25 layout and the dimension text is massive!
Please help,
Henry
Update:
I just read http://archicad-talk.graphisoft.com/viewtopic.php?t=25645&postdays=0&postorder=asc&&start=0&sid=5b95...
which deals with the problem but does not help me.
Here is a screenshot of my LAYOUT on A3 paper. Exactly the same view but at 2 different scales. The title "TYPICAL SECTION" is at 3.5mm. Now the dims in 1:25 are going to print EVEN BIGGER! And in 1:100 you can hardly see them. The dimtext is scaling in relation to the scale but shouldn't. How do I get the dimtext to appear 2mm on the layout regardless of scale?
4 Replies 4
rocorona
Change the scale of the drawing BEFORE saving it as a View.
My English skill is not enough to explain it deeply, but sure someone will do if you need some further.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
David Maudlin
Henry:
Also see this thread:
Dimension marker size should be as small as text size
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Thanks, works well in a rounabout kinda way!
While I am on the subject, I work in mm, so if something is 1m it gives me 1,000 and I want 1000 - how do I get rid of the comma?
Ta,
H
rocorona
If I undestend it correctly, I think you have to change the setting in your system (PC control panel).
_________________
--Roberto Corona--
www.archiradar.com
_________________
_________________
