Shadows in architectural documentation
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2020-06-04
02:42 PM
2023-06-07
11:21 AM
Gordana Radonic
Please, fill out our Survey!
https://bit.ly/3caSsnn
Design Services Lead, Graphisoft
- Labels:
3D Document
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-01 04:01 AM
Barry wrote:
Are you aware of the "Marked Distance Area' option in the settings for sections and elevations?
Not a 'fog' as such but it does reduce the weight (and color) of the linework in the distance area that you set.
Thank you so much. I am aware of this feature and I have used it. Maybe I need to play a bit more with it. What I have seen on other software drawings is lines getting automatically dimmer as you get farther and farther away from the elevation or section line. I think in Archicad you are only allowed one iteration of lighter linework. Probably not a critical item but it did look very nice for schematic linework, less important for construction documentation.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-01 04:07 AM
I think it is around 50%.
It is also rather abrupt when you have elements that span through both distance areas, like angled walls or roofs with a surface hatch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-01 11:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-01 03:16 PM
DGSketcher wrote:
I guess technically the OP was about shadows but this thread has taken on a wider trajectory that suggests perhaps GS should be thinking more in terms of preset presentation settings for views with more than just shadow adjustments. If that were the case then fog / fade adjustment would be a nice addition. In section / elevations this could be simply controlled by the Limited Range depth markers representing 0 - 100% fade.
Sorry I did not mean to derail the conversation. I can post this in the appropriate thread after we see what the new version has in store for us.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-01 08:29 PM
Thank you for your positive contribution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2020-07-02 12:38 AM
Also, i would really like to see what Mr. Tomek proposes with the ambient oclussion for white view.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2022-03-22 11:33 AM
Yes I do take pride in architectural documentation - do GS? Ambient occlusion and ability to have shadows from cutaway objects are two straight forward features that you can't ignore if you are earnest in the effort to improve shadows in AC. Is there a report of this survey and any resulting improvements?
- « Previous
- Next »
- « Previous
- Next »
