Shortcut for H and V length
In AC9, when drawing (say) a rectangle polyline I could specify the height and width by using the "X" and "Y" shortcut on the keyboard. But in AC10, X and Y refer to the X and Y co-ordinates (and hence my polysquare ends up in the wrong place with the wrong dimensions).
I can't seem to find the shortcut for Length - H and Length - V. Could somebody help me out?
Thanks!
10 Replies 10
Using the Tab key, (and Shift+Tab) will toggle through all values in the Tracker, assuming you have the Tracker on...
Hopefully, this is what you are after...
Alan
Dwight
I suspect that the problem is relative versus absolute coordinates as set in the coordinate box.
check the delta box and see if the behavior changes.
Dwight Atkinson
Yes, I have the Tracker on and I know I could Tab, but I was hoping to get a more direct shortcut. (Old habits die hard?)
I tried changing various combinations of setting and un-setting the two Delta boxes, but that didn't seem to help. When I press X I get sent to the X cordinate in the Tracker and if I change that value, the Length value also changes automatically (to the "wrong" value).
Djordje
Did you try the age old, but rarely used (or known) x+/- and y+/- ?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
On my system, if the Tracker is on, you can just start typing a value and it goes right into the "H" field; NO NEED FOR A SHORTCUT. Then Tab to V.
Richard
AC26 (since AC6.0), Win10
__archiben
really? shocking!
what happens when your grid is skewed to 45º? which way is 'H' and which is 'V'?!
~/archiben
b e n _ f r o s t
~/archiben
No problem. You just tilt your head.
Richard
Djordje & Richard, Thanks!
I think I see what Alan was pointing out too- as in Tab directly to the Tracker. I thought he meant press "x" and then Tab to the Length - H.. doh.
Aussie John
~/archiben
Typing "X" and "Y" seems to work for a skewed grid (or normal for that matter)
Type a for angle,
d for distance (also the legacy r)
Cheers John
[/size]
