‎2017-05-20
12:13 AM
‎2023-05-22
11:55 PM
Gordana Radonic
‎2017-05-20 01:13 PM
Jeanie wrote:There are two things to do: use Display Order on the Fill to Send Backward until it is behind the Story Levels. Also, the Built-in Story Marker has a background fill (Story Levels > 2D Representation > Fill Type, so set its Fill Background Pen to a white pen, so the text has a fill under it.
I would like the Story levels be visual above all other layers. For example:
I sometimes create a fake terrain to make the Elevation or Section present the way I would like using a fill. But then the Story Levels get hidden behind that. Is there a way to change the setting so Levels appear about the layout as in Master layouts.
Jeanie wrote:Look at Preferences > Dimensions... > Level Dimensions (4th button from left) to set the Story Marker dimension units. Your Dimension preferences should be stored with a name (not Custom) and assigned to your Views.
Second question as it pertains to Story Levels.. how do I set the fractions of the Story Levels. I don't necessarily want them to show with 64th inch fractions. I thought if I I changed my dimension units or working units for my view, this would also change it in Story levels, but not so. I could not find another way to change those settings. There has to be a trick.
‎2017-05-23 03:00 AM
‎2017-05-23 02:07 PM
‎2017-05-23 04:17 PM
Jeanie wrote:With Archicad 21 being the first full digital release (yep, no more box versions) there is little chance this will ever happen.
I miss having a paper manual to cruise through. Hope that cycles back around.
‎2017-05-24 03:06 AM
runxel wrote:Especially not with a 3500 page manual.Jeanie wrote:With Archicad 21 being the first full digital release (yep, no more box versions) there is little chance this will ever happen.
‎2017-10-06 02:48 AM
