Text
I have a question on text. When I make a text box - alignment left looks correct, alignment center the text does not center in the box and exceeds the text box on the right, alignment right the text mostly exceeds the text box on the right. The settings are set to text wrap and the anchor point makes no difference. If I ignore this situation, when I create a pdf, the text is presented where it should be although it is now misaligned compared with the pln file.
Could you post a screenshot that shows all the states that you mention in your post?
