The true line weight
I have been getting into some trouble with the true line weight feature.
I usually find it disorienting to work with the true line weights on. It is difficult to be absolute about where I am making marks and marring nodes. Some times the true line weight does not transpose into the PDF. documents when I have the feature turned off and I publish a document.
I find it odd that that would even happen, but does any one know how to avoid this problem, as I am constantly forgetting to turn the feature back on.
(Keeping in mind that I need to have it turned off to work)
I might just have to risk having mistakes if this persists!
Thanks
1 REPLY 1
What version of AC are you using? True line weight is a display option, and should not effect output. You may have the "Hairline" box checked in the Print dialog.
