ares997
Title 24
I want to be able to transition between two different window and door markers so that I can export information for a title 24 consultant. Any suggestions? Basically the difference is that on the Schematic or Construction Documentation the markers can both be totally different, and then with T-24 that is also a different type of marker in the office but getting the markers to be variables within the set or the type of set would be nice.
Your thoughts are appreciated.
Archicad 25 (5005), Windows 11, AMD RYZEN 7 3900 (64 GB RAM)
The simplest approach would be to make a quick global change at print time. Select all the doors/windows (you can do them all at once in 3D) open the settings dialog and change the marker setting. Update all the drawings in Drawing Manager and publish.
ares997
Is that what you do when you need to create a t-24 sheet?
