Top view of roof window
chora
I have roof windows that show on the plan the whole structureof the window - that I don't want to see (Bild 2) (the interior part of the window construction) .
When I copy the roof into a new ArchiCad file, it is displayed the way I want it. So I think, that it is a setting of the visual representation in ArchiCAD.
Since it is a large project, it would be complicated to copy everything to the new file. If anyone knows how to solve the problem, I would be grateful.
Bild 2: Existing view
Bild 1: Desired view
Operating system used: Mac Intel-based
12 REPLIES 12
BrunoH
Hi Chora,
Does the file came from an older version of Archicad ?
If yes, check the status for previous version in Project preferences.
ArchiCad 3.43 to 28
MacOS Monterey
Thanks Jeff,
the thing is that by exporting MVO to the second file it shows correctly there. Also I have checked all your suggestion, but I don't think the problem is in MVO. So it is still unsolved...
Thanks a lot!!!🙏
Setup info provided by author
