2019-09-16
01:44 AM
- last edited on
2025-08-04
04:19 PM
by
Aruzhan Ilaikova
Solved! Go to Solution.
2019-09-16 02:50 AM
2019-09-16 02:50 AM
2019-09-16 03:06 AM
Barry wrote:Dind't know that the order of objects in plan view are different from the 3D. This anwser lots of questions. Thanks a lot!
I am assuming that you have used the slab tool to model the horizontal wood.
By default a slab does not have a cover fill.
However you can turn on the cover fill in the slab floor plan settings - make it solid white if you do not want to see it but want it to hide other elements.
You may need to use the 'Display Order' (forwards and backwards) to arrange your elements in plan as they have a default display order that has nothing to do with their position in 3D.
2019-09-16 03:16 AM
