Units Display Problem
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2015-10-07
03:11 AM
2023-05-19
03:54 PM
Gordana Radonic
It happens in dimensioning and text elevation.
Ho to fix this?
Regards,
Jae
(AC 19 Update 4006)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-07 04:16 AM
Maybe that was not the case now?
Have you checked your number formatting and language setting in your Operating System?
I am not aware of any settings in Archicad that would do this.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-07 08:50 AM
I have try to set compability mode (The AC 19 runs on Windows 10 64x), and the problem still there.
If I run AC 18, there is no problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-07 09:00 AM
Maybe it is just a problem with 19.
I have 19 (although I am not really using it) but I only have Windows 7.
Plus I don't use imperial measurements.
Maybe someone else with Widows 10, Archicad 19 and using Imperial units can say if they are having this problem or not?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-07 02:34 PM
The case happens for labeling too (such as +4.00 that will be change automatic to 4.00+) even if in Metric.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-08 03:08 AM
Jae wrote:I did try but had no problems.
Would you to simple test your AC 19 dimensioning and elevation label in Imperial units?
So it is either a setting in 19 that I am not aware of or an issue with the combination of AC19 with Windows 10 that doesn't affect AC18 / Windows 10.
I'll have another hunt around in 19 when I get the chance.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-10-09 03:13 PM
Otherwise you could try a New & Reset holding the option/alt key down when you open a new file or even try re-installing AC19.
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2015-12-01 03:48 PM
The problem is that the dialogue manager gets the language setting (and decides on the writing direction) based on the operating system info, while the setting should originate from the keyboard's input setting instead. The problem does not currently have a high priority to be fixed. Tx, k
Implementation Specialist
GRAPHISOFT
