Using standard notes across multiple projects
I am tired of copying and pasting standardized notes from one project to another. I thought I could set up in a template, but the template does not update when I change notes or details. How are people using standardized notes and details across multiple projects? Modules? Importing drawings?
Using ArchiCad 23
3 Replies 3
vistasp
Mentor
Hi gjparadigm. Have you considered placing PDFs in your layouts?
Unfortunately the images are missing in the first link, but you'll get the idea.
https://www.actemplate.com/tips-tricks/using-pdf-files-in-archicad/
https://www.cadalyst.com/aec/archicad-insights-placing-pdf-drawings-archicad-projects-3322
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Thank you for responding. I do use PDF's for standard City details, but I wanted to be able to change notes and such on a more consistent basis since the City always has a different comment depending on the reviewer. Right now I am using a separate .PLN file that is linked to the drawing, but sometimes that causes lagging issues.
I may just have to go with a linked PDF that can change as needed.
jl_lt
Ace
I use a dwg file for notes that i attach to the template as a worksheet and then place it in the layouts as needed. This way, if i update the dwg it updates everywhere (of course, if you add many more notes you have to adjust the layout size, but thats a minor inconvenience. Hope that helps!
