Vectoral Fills issue
I seem to have some issue with fills when trying to show slabs above on lower levels. I have a composite slab with ties shown as a fill pattern. When I set the slab to show on the lower level, the edges are dashed, which is correct, but it still show the tile fill pattern. How can I hide the pattern on the lower floor?
3 Replies 3
David Maudlin
seabassvg:
Go to Slab Settings > Floor Plan and Section > Floor Plan Display > Show on Stories and select Custom. In the Custom Settings dialog box you can set which stories to Show Fill on.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Awesome thanks David it worked. I'll update my signature now.
David Maudlin
Sebastian:
Thanks for reporting back and adding your signature.
David
