View Map drawings into layout
All,
Help, Help!
I drag and drop a view map item (drawing) into my layout and it appears UP SIDE DOWN all the time.
I have to go into the drawings settings and change the angle from 180 to 0 ALL the time.
Is there any auto setting in archicad that specifies the correct angle of the drawing dragged onto the layout automatically?
Thank you in advance for your help!!
Best DDJUSA
5 Replies 5
Link
Like any other tool in ArchiCAD, set up your default first. That is edit your Drawing Settings, with nothing selected. Every drawing placed after that will take on those settings.
Link.
Thank you!!
But do you know where are the drawings settings without selecting anything?
I can't find the drawing settings tool
Sorry
THX
DDJUSA
Or, like any other tool in ArchiCAD, once you have your placed drawing corrected (i.e. 0 degrees) pick the properties up with the syringe. Every drawing placed after that will take on those settings.
DDJUSA wrote:
Thank you!!
Sorry
THX
DDJUSA
Drawing tool...
THANK YOU THANK YOU THANK YOU!!!
Best,
DDJUSA
