SOLVED!
View Map
13senpai
Hi
Can someone explain what this is please?
How group my floor plans like this ?
1 ACCEPTED SOLUTION
Solution
vlahtinen
That's a clone from the Project Map, in this case from Stories, but can be created from other Project Map folders (eg. Sections etc.) as well. see Clone a Folder in the View Map
2 REPLIES 2
In the view map you can create as many view of the view points in the project map as you like.
You can create folders and group the views as you like or you can clone the view point groups from the project map, but cloned folders can not be customised.
I could write a very long how to explanation, but it may be better to read the help files and if you have further questions, ask again.
https://help.graphisoft.com/AC/28/INT/index.htm?rhcsh=1&rhnewwnd=0&rhmapid=#t=_AC28_Help%2F030_Inter...
Barry
Solution
vlahtinen
Setup info provided by author
