gdford
View Properties in Organizer is not correct!
  1. select a view from the view map in the organizer
  2. open the View Properties Tab at the bottom of the organizer
  3. click the setting button at the bottom of the organizer.
  4. compare the graphic override between the setting and the view properties
    1. they are not always the same????
note the attached file for the image above.
Gary Ford
Self Employed - Modeling, Estimating, Construction
Archicad 12-26
AMD Ryzen 9 5900X 12-Core Processor
3701 Mhz, 12 Core(s), 24 Logical Processor(s)
(RAM) 128 GB
NVIDIA RTX A2000
0 Replies 0
