Mac_the_arc
View showing black on layout
I have placed a few views onto a layout, and for some reason the elevation views are showing solid black, despite the actual view having a GO applied.
 Has anyone go any suggestions on why this is happening?
3 Replies 3
DGSketcher
Legend
Check the Drawing Settings on the Layout and make sure the colours are set to "Defined by Pen Set". If you are using Black & White or Grey Scale, it may be the GO's have created this problem. I assume in the View Map the elevations look as expected?
Mac_the_arc
yes everything looks fine in the view map. I tried the drawing settings in the layout and they are set to 'Defined by Pen set'.
DGSketcher
Legend
See if your Elevation Settings > Model Appearance is using Uniform Pen Setting overrides?
