2022-12-07
10:07 AM
- last edited on
2022-12-29
01:36 PM
by
Rubia Torres
I have placed a few views onto a layout, and for some reason the elevation views are showing solid black, despite the actual view having a GO applied.
Has anyone go any suggestions on why this is happening?
2022-12-07 10:31 AM
Check the Drawing Settings on the Layout and make sure the colours are set to "Defined by Pen Set". If you are using Black & White or Grey Scale, it may be the GO's have created this problem. I assume in the View Map the elevations look as expected?
2022-12-08 02:17 PM
yes everything looks fine in the view map. I tried the drawing settings in the layout and they are set to 'Defined by Pen set'.
2022-12-08 03:06 PM
See if your Elevation Settings > Model Appearance is using Uniform Pen Setting overrides?
