Visibility of sections and elevation lines
Im sure im missing something, but is there a way of seeing an elevation or section line without seeing the entire parameter?
For instance this view has only 4 elevations, however im not only seeing the section markers, im seeing the extent parameters to both sides, and the depth. This is producing a very cluttered view.
2 REPLIES 2
runxel
Hero
But that's just onscreen (not visible in outputted plans) and also you can disable them, I think.
Yes, the marker range can be turned off in the on-screen view options, and they don't print as mentioned.
Mac_the_arc,
Please try to post in a relevant section of the forum and not the 'Archicad+' section which is for discussions about Archicad and not problems encountered.
I have moved the post.
Thanks.
barry.
