Welding line
Borgo1971
Someone knows if and how to create a Linetype for welding symbol? I mean a  a sort of comb, with the teeth all on one side of the line?
since ArchiCAD 4 now 27 on
MacPro 7,1 12x3,6GHz 64GB ram, powered by macOS 13.6.7
MBP 16" 2019 i9 8x2,33GHz 16GB ram, powered by macOS 13.6.7
Gerry Leonor
not specifically a tutorial for Welding Linetypebut helpful & relevant nonetheless.
https://www.youtube.com/watch?v=zJd_0eJQfeI&t=213s
this has helped me make custom linetypes many times.
From memory, you need to be at Project Origin for the spacing & scaling to work, otherwise it'll be confusing when you try & mess with the sizes & gaps of the curved lines.
https://discord.gg/XGHjyvutt8
Gerry Leonor
Borgo1971
Thanks, it helped me too. Even I started from scrap to try to create symbol line with lines referring to Design origin. I guess my fault was I did it from a worksheet and not from 2D plan..
