Jon:
I am not sure if it will standard 24X36 plots. Do I need to get the HP 36" or can I print it in a landscape form.
I'm using an
HP DesignJet 130nr. (w/ Mac OS 10.4)
It's a 24" wide printer and I can print 24" x 36" sheets, no problem. I assume the 430 will do likewise.
A word of caution on the 130. It's geared more to the Graphic Artist / Photographer..... it uses a "dye" ink, instead of a "pigmented" ink. As a result, T-bond and vellum papers are not "supported" media. I've been able to print using t-bond by trial and error (print settings). The prints are a bit soft (FUZZY). Has anyone else dialed in these settings??
The HP purports? it's
100plus is a CAD printer. " No compromise CAD results".
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/18972-236251-236266-12600-236266-352395.html
It's a color printer and it uses pigmented ink. It should print cleaner black lines (like the 500 series) but it seems useless to me as it lacks a roll feed attachment. I spoke with an HP Rep, and she said they may be adding a roll for this printer (US market), but you may have to wait awhile to see it. On the plus side.... it sells for under US$1,000.
Good shopping.
Marco
Marc Corney, Architect
Red Canoe Architecture, P. A.
