Which Dimension feature is this?
Hi all & especially Italian members,
In this video for @Luca Manelli, he was describing a new feature (for me) regarding Dimension in a short clip shared via linked-in.
Kindly, If any one can help me understand it, thanks in advance.
https://www.linkedin.com/posts/graphisoft-italia_archicad-graphisoft-activity-7245002665263288321-Fr...
AC 29 INT 4006/WIN 11
1 Solution
Hello @JeffH,
Yes, this feature called (Merge Dimension Chains), since Archicad 19 & earlier but I never heard about.
*Here’s the video explaining it in more detail.
https://youtu.be/er6DoaYuXno?si=274EnJvOUESjhF8B
**Thank you all for your help.
Go to post
4 Replies 4
Emre Senoglu
It's the regular dimension tool. Here's a short how-to video in english: https://capture.dropbox.com/Mya6QlymMZ3k0IAD
*edit: to correct and clarify the instructions:
1- select dim 1
2- press+hold: cmd (for Mac) / ctrl (for win)
3- select dim 2
AC27 ARM // MBP M2 Max // Twinmotion | Corona | Rhino
senoglu.co | archimats.com
Hi @Emre Senoglu, Thanks for clarification.
Luca had explained it well & even replied to me via LinkedIn exactly as you thankfully mentioned.
I need to know the name of this feature, where is it in the help guide? Is it included in pet pallete?
JeffH
In the Help manual, I believe it is under
AC24 / AC26 / AC27
Win10
Hello @JeffH,
